Apr 25, 2006 #1 H has_ajam Advanced Member level 4 Joined Dec 9, 2005 Messages 115 Helped 3 Reputation 6 Reaction score 0 Trophy points 1,296 Activity points 1,990 have any body a good paper that says about relation between phase noise and jitter ? that says what is the equivalent of n ps jitter to m dBc phase noise at for example 10kHz offset
Apr 25, 2006 #2 M methisherenow Newbie level 6 Joined Jan 23, 2005 Messages 11 Helped 2 Reputation 4 Reaction score 0 Trophy points 1,281 Activity points 150 This application note from MAXIM has a good description. **broken link removed** It also has some reference papers at the bottom. Hope it helps.
Apr 25, 2006 #3 D danda821 Full Member level 2 Joined Jun 18, 2002 Messages 139 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,296 Activity points 1,083 You can find the answer in the following paper: https://www.designers-guide.org/Analysis/PLLnoise+jitter.pdf
