electronicsIdiot
Junior Member level 1
hi,
I am trying for interfacing lcd with 89s52
for connection purpose I soldered the pins 1..16 with a connecto
so before interfacing I try to test it up.
When I connect 15(back LED+),16(back LED-) with battery yellow-green led light ups.
but When I connect 1(ground),2(Vcc),3(Vee contrast with a resistor ) with battery the rows or column of lcd shows no indication of life.
Is it shows my lcd got damaged or Is it ok to show nothing so that I can follow
to check LCD completely.
and also give me some easy and cheap methods by which I can check the lcd
