hi,
i wish to interface jhd162 a with atmega16 microcontroller..i am using code vision avr as the programmin software..
please help me with the programming part of it to display all the alphabets with some delay!!
If you want to do 4 bit mode with lcd, you cna get code from code wizard itself as you are using codevision avr. Just make new project in codevision avr then it will ask whether you want to use code wizard or not. After selecting that you can ask for that code.
Codewizard always gives running code. I have seen your code. Seems there is no problem. Please check your hardware. Lcd getting enough voltage? Connections are ok?
