ikhan42
Newbie level 5
- Joined
- Aug 1, 2013
- Messages
- 8
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 94
Hi Everyone,
I am looking at building a pickit2 programmer and ofcourse I need the chicken or is it the egg LOL.
I need a programmer that can program the 18f2550 microprocessor. I have found a circuit at the following address https://electronics-diy.com/electronic_schematic.php?id=823 but am a little confused with their wiring diagram firstly they are using the 2n3904 transistor but Q1 on their circuit diagram has me confused it is the wrong way around I understand that they can mirror it but I just want to confirm that the c and e pins are going to the right locations on the circuit diagram.
Also with regards to the resistors they dont advise wattage for resistors do I assume 0.5watts?
Also can someone tell me what the ground is meant to connect to. When I load the circuit on eagle schematics it leaves the ground seems to be of c2 not connected to anything.
Any help would be greatly appreciated.
Just to give some background. I am looking at building a UV exposure box that will run of a pic16f84-04 timer. I want to make this box as my 11 year old wants to learn programming and electronics and is also getting interested in Robotics so I figured a UV exposure box for making PCb is a good place to start. I will then use the uv exposure box to build a pickit2 programmer. I have some books on robotics and pic micro controller and then my son and I can start learning together.
Hope someone can help me with my Question above and sorry if the background wasnt needed or boring (lol)
Thanks
Ikhan42
Thanks
Ikhan42
