buenos
Advanced Member level 3
- Joined
- Oct 24, 2005
- Messages
- 960
- Helped
- 40
- Reputation
- 82
- Reaction score
- 24
- Trophy points
- 1,298
- Location
- Florida, USA
- Activity points
- 9,116
hi
it seems synpify ignores my false path constraints.
i set up false paths:
the point is that fpgareset_n is synchronised to x32_clk_better, and that is asynchronous to the other circuits, driven by the x66mclk, fpga_pciclk and x2510_clk8.
I keep getting timing violations on paths going through fpgareset_n
what constraint should I set up to disable timing checks on these paths?
because it seems my constraints are not effective.
[/code]
# Clock to Clock
define_clock_delay -rise {fpga_pciclk} -rise {Inst_businterfaces.ldt_clk} -false
define_clock_delay -fall {x32_clk_better} -rise {x2510_clk8} -false
define_clock_delay -rise {x32_clk_better} -rise {x2510_clk8} -false
define_clock_delay -fall {x32_clk_better} -rise {x66mclk} -false
define_clock_delay -rise {x32_clk_better} -rise {x66mclk} -false
define_clock_delay -fall {x32_clk_better} -rise {fpga_pciclk} -false
define_clock_delay -rise {x32_clk_better} -fall {x2510_clk8} -false
define_clock_delay -fall {x32_clk_better} -fall {x2510_clk8} -false
define_clock_delay -fall {x32_clk_better} -fall {x66mclk} -false
define_clock_delay -rise {x32_clk_better} -fall {x66mclk} -false
define_clock_delay -rise {x32_clk_better} -rise {fpga_pciclk} -false
# Delay Paths
define_false_path -through {ldt_mode}
define_false_path -from {{i:Inst_businterfaces.ldt_csr_reg[7:0]}} -to {{i:Inst_businterfaces.ldt_reg}}
define_multicycle_path -through {Inst_lpc_interface.downstream_match} 2
define_false_path -through {fpgareset_n}
define_false_path -from {{i:x32k_clk_better}} -to {{p:x66mclk}}
define_false_path -from {{i:x32k_clk_better}} -to {{i:*2510*}}
define_false_path -from {{i:fpgareset_n}} -to {{i:*}}
define_false_path -through {fp_switch_db_n}
[/code]
