Hi All,
I am trying to measure the return loss of a number of passive loads using a directional coupler + signal generator(SG) + spectrum analyzer(SA) with the setup shown.
I basically generate a CW at 500MHz with the SG and feed to the coupler and
a) terminate the out-cpl port and measure power from the in-cpl
b) terminate the in-cpl port and measure power from the out-cpl
subtract the two measurements to measure the return loss.
The parts/instruments used are:
- SG - N5181A
- SA - N9010A EXA
- Coupler - Minicircuits ZFBDC20-62HP+S+
- Minicircuits 50Ω terminator
I have noticed that my results are different from the VNA measurements:
Load | Measured return loss(dB) | VNA measurement(dB) |
A | 8.11 | 7.47 |
B | 10.7 | 9.6 |
C | 11.7 | 10.2 |
D | 12.4 | 12.2 |
I am using a small RBW and 10dB attenuation on the SA.
What is causing this error in my measurements? Is there a way to improve the accuracy of my measurements?
Thank you
