Issues with high imd3 while using mrf9085
zzj
Junior Member level 1
mrf9085
Hi
I am useing the mrf9085 to do cdma hpa(10w).but i found it's imd3 is very high.i can't work out.
could you help me?
thanks
MoonShine
Member level 2
Member level 2
Did you measure the ACPR?
MoonShine
zzj
THANKS!
I measured the ACPR,It's OK!But the IMD3 is OK when it's output power is 8w.
Did you use the mrf9085?could you help me? thanks!
MoonShine
Member level 2
Member level 2
Yes Im familar with the 9085. I believe it's optimized for the backed off condition. The IMD's would depend on the bias point, how are you testing?
MoonShine
