Nikolai
Member level 3
Firstly i'd like to know the difference between the following modes:
(Im referring to the Xilinx XST userguide)
1.) Read first
2.) Write first
3.) No change..
Secondly, in the following code (No change mode)
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity rams_03 is
port (clk : in std_logic;
we : in std_logic;
en : in std_logic;
addr : in std_logic_vector(5 downto 0);
di : in std_logic_vector(15 downto 0);
do : out std_logic_vector(15 downto 0));
end rams_03;
architecture syn of rams_03 is
type ram_type is array (63 downto 0) of std_logic_vector (15 downto 0);
signal RAM : ram_type;
begin
process (clk)
begin
if clk'event and clk = '1' then
if en = '1' then
if we = '1' then
RAM(conv_integer(addr)) <= di;
else
do <= RAM( conv_integer(addr));
end if;
end if;
end if;
end process;
end syn;
a.) why is ram_type defined as a "signal". wouldnt a "variable" do just fine or mebbe better since there are no delays associated with it.
b.) why are input and output ports seperate. Isnt ram supposed to have a single data bus ? Further will the multiple driver resolution problem arise if i declare the data bus as INOUT.
1.) Read first
2.) Write first
3.) No change..
library ieee;
entity rams_03 is
we : in std_logic;
en : in std_logic;
end rams_03;
begin
process (clk)
begin
if en = '1' then
if we = '1' then
else
end if;
end if;
end if;
end process;
end syn;
