Hello ,
I have a PCB which contains digital section responsible for generating PWM signals and many more functions and a second section with a three phase power supply. I am using a 24V supply for the Three phase and realized that I need to use the same 24 volt (after being regulated/converted using buck) to supply the digital section with multiple voltages. My question is how to isolate the 2 sections? Is there a component that can be used to supply both circuits from 24 volts but at the same time isolate them?
Thank you very much!
what did you use to convert the 24 V " to supply the digital section with multiple voltages. "?
there are several manufacturers of dc to dc converters that isolate input from output.
one place to start looking is digikey
use the selection tables to narrow down the choices
i suggest you select "active" and "in stock" first, then by the most important properties of the converters you seek
So you are using a three phase supply to generate an isolated 24V?
Or is it you want to know how to generate an isolated 24v from a three phase supply?
If its low power then just use one of the phases to generate the 24V...start with a diode rectifier.....then say a power integrations based flyback converter with isolation...the PI expert software will designe it for you.
Is this a electricity metering application?....there are examples of such on power.com site.
