ISE 14.7 & Matlab 2014
shazdek0ch0l0
Member level 3
Member level 3
I installed Matlab 2014 and ISE 14.7. but these two softwares not configured in system generator and it shows not supported,
how can i solve this problem? i want to configure these two.
thanks
As nobody has answered.
You probably can't use Matlab 2014 as it didn't exist back in Oct 2013 when ISE 14.7 was released. Even if it did work you would probably run into issues of compatibility. Either use a version of Matlab that is 2013 and supported by ISE 14.7 or switch to Vivado if you're using a 7 series or newer part.
Regards
