I need you to judge that the guy who has designed this PC board has knowledge of RF circuit design or not ?
This is VHF PCB board @950MHz, the PCB board has 8 layers
I don't know why he routed RF trace at the edge of PCB
should it correctly be routed like that ?,
how did it mange to guarantee of 50-Ohm impedance ?
In fact, there is not so much Microstrip structure on that PCB.So, it should be ok..
But if the frequency is high enough, changing the Microstrip Line from 1-7-1 may create a problem if the Impedance Matching or other constraints are tight.
We should know the application and if it's possible the schematic.
