Is there such thing as a Normally Closed Mosfet or transistor like as?
Iraianbu
Is there such thing as a normally closed mosfet? or can I somehow make a circuit ? can I control circuit one functions like as a control logic voltage 3.3v or 5v. when I give logic normally closed circuit change to normally open?
Solution
"depletion mode" is your search key. Many "RF" GaN, all GaAs and
silicon MESFET / JFET types are. You can find depletion mode Si
MOSFET discretes and dual-gate. I have worked in technologies
which had high, low, intrinsic and depletion VT on both N and PMOS.
Now that's a salad.
dick_freebird
Advanced Member level 7
USA
Now that's a salad.
Solution
Iraianbu
Now that's a salad.
Depletion type MOSFET cost is high. I need Low cost and Simple Circuit like as this DMOSFET.
crutschow
Advanced Member level 6
Colorado USA Zulu -7
A P-MOSFET with the source connected to V+ and the drain as the output will be on when the gate is low (ground), giving a high-side switch.
Will that do what you want?
dick_freebird
USA
If you mean, as the original post, that the transistor itself
should conduct without imposing a different bias voltage to
it, then complex circuits don't fit that frame.
But maybe it's a frame problem.
stenzer
Advanced Member level 3
what are you design constraints e.g. current, voltage ratings, high-side or low-side application? You also can create the desired function with two transistors e.g. a N-MOSFET and P-MOSFET or even BJTs.
BR
LaTeX Commands Quick-Menu:
