is there any way about making error expression error count?
u24c02
Advanced Member level 1
When i trying to run with Makefile, the error message just expressed each 10.
So i want to see more like 100, but i dont know how to do that.
Ur question is not clear....
I meant that when i was runing the Makefile, then The makefile's results are printed to monitor.
so the makefile that are printed error messages are just 10 of 255.
when i trying to run every time, so the error message are just 10 for each run.
I don't understand. is there any options?
Why do you want more error messages? Anyways, it is printing 10 everytime because the case ends at that point everytime..
I hope I have understood your question...
Any one error can cause a tool to print out alot of error messages. For example if you forget to add the endmodule to a verilog file you will see hundreds or thousands of error messages as it tries to compile the next module.
You should only fix the first error that is listed and then rerun the tool to see if any of the other errors have disapeared on their own.
Thanks,
"to compile the next module.
You should only fix the first error that is listed and then rerun the tool to see if any of the other errors have disapeared on their own."
Is there any way to show me for example?
