Is there a easy way to place stitch vias in CADSTAR?
swen_s
Member level 1
Is there an easy way to place stitch vias in CADSTAR?
I want to connect (stitch) two copper areas located on two different planes, both are GND.
I fail when I do this. The copy does not work. Could you specify step by step how you do it?
This needs to be done in PREditorXR as that is the only place you have this functionality.
If you have the ability to copy/paste tracks then you can select a via and copy/paste it.
You need to unpour any positive pours underneath so you can paste vias connecting ground pours only.
If you cannot copy/paste then start routing, double click to put a via in then escape to stop the route.
Do this at every point you want a via.
Consider making a via grid to get them nice & lined up.
