is the netlist edf same as edn ?
buenos
Advanced Member level 3
Florida, USA
edf is the same as edn ?
hi
my actel program in some cases it generates an EDN netlist, some other cases it generates an EDF file.
can i use the EDF file for P&R the same way as I use the EDN?
what a @x!# is EDF anyway?
devas
Full Member level 2
Full Member level 2
Re: edf is the same as edn ?
You can check this by opening the edf file in a text editor. When it is an EDIF file (as I expect) than it should start with:
(edif <name>
If it is an EDIF file I should expect that you can use it like an EDN file.
Devas
