jonatan
Member level 1
I have a DIGILENT D2S board with Spartan2E- (XC2S200E) with 50MHz clock in the board and one A/D converter ADS2807 from Texas. The A/D works with the clock range from 100Khz up to 50MHz, and do the conversion in continuous acquisition mode.
I would like to know if is safe to create a clock with 25MHz from FPGA board througth clock divider (50MHz/2) to serve as input clock to A/D using LVTTL I/O drive configuration in FPGA Pin out?
How do the FPGA behavior about temperature in this case? Is there a limit to this temperature, of course, can someone explain something about that?
Do I need to verify this case in "Analyse Power (XPower)" option in ISE.
Thanks in advance...
