nadabro
Member level 4
Hi.
I´m using a sensor with a 24bit ADC (Sensor -> Zero-Drift Op Amp -> ADC) sampling at 41SPS (23bit -3dB at 11Hz, 40Hz cut off), i´m happy with the results, but i´m having a background noise:
ImageShack® - Online Photo and Video Hosting
The results in the image are divided by 12, so it gives a noise count of +/- 5000 (in 23bits).The noise is kind of wavy, do you think this noise is from the circuit or from the ADC? The circuit is already mounted in the PCB so i cant change nothing on it..but using oversampling or other technique is it possible to reduce the noise?
Never used ADC at so high resolution, dont know what to expect from noise count.
Thanks.
Thanks.
