vioamethyst
Member level 3
i need some guidance here
im a very new learner in any hardware design
in the store nearby
i only have the option to buy either IC-ADC-0832 and IC-ADC-0831, and i have to concern over low cost because my design is emphasizing on low cost design, the other ADC chips is expensive and too many input (which is nt my requirement)
since IC-ADC-0831 required differential input, bt my input is not of that type
so i shose IC-ADC-0832
my input will be from amplifier LT1013, which have two output , this output will be chose only one by using switch, then the single output will be as input of IC-ADC-0832 that futher connected to PIC 16F84A
i may sound stupid by asking this (sorry for my low knowledge), bt below are my question that i need some expert can asnwer;
1) IC-ADC-0832 is two analog input ADC, bt mine only have one analog input to it, is it possible to use the ADC chip? does it mean i can just igno the connection to other single input and single output at that chip?
2)is there any programming required for configuring that IC-ADC-0832 or it can directly use to function as ADC just as simply connecting it to other component?
3) is this IC-ADC-0832 is compatible to interfacing with PIC16F84A? if there is any link on programming that can guide me , plese kindly provide me
my hardware will be use to measure power from fiber optic, thank you
i really look forward for any guidance from people here
please forgive me of my poor english proficiency
thnk u very much
in the store nearby
thnk u very much
