Is it possible to design an antenna for both 2.4G and 5.8G?
iamchrisk
5.8 antenna design
Hi
As I don't familiar with the antenna design.
I would like to design an antenna for both 2.4G and 5.8G.
Any suggestion? or Any books or reference that i can read before simulation?
Many Thx.
2.4g antenna design
Try Fractal antennas :idea:
Re: Is it possible to design an antenna for both 2.4G and 5.
are you thinking in a wide band antenna(more than 1 octave) or just an antenna covering two narrow and differents bandwith?????
Helicoidal antennas are used for wideband but i don't really know if it could be a good idea having in mind the frequencies you are talking about
bye
Hi iamchrisk,
it is possible. A simple example will be a patch antenna (designed to operate at 2.4GHz and to obtain a 5.8 GHz operation cut an appropriate slot in the patch.
Element7k
iamchrisk said:
Hi
Many Thx.
of course ,a LPA can do it easily,you can try
iamchrisk said:
Hi
Many Thx.
some of the books which might help you are "Antenna and EM Modeling with Matlab by Sergey N. Makarov" and "Antenna Theory: Analysis and Design, 3rd Edition by Constantine A. Balanis",..these will give you a very good perspective in RF component design and its implementation.
look up the pifa paper by WONG. it's even on the board somewhere.
Try using "Ontenna OPtimizer " or HFSS from ANSOFT ,,
if possible, pls check the ieee mwcl magazine. in the recent volumes, there is a proper paper about it.
I'm lookinf for a microstrip patch configuration gaining more than 40 dB in double polarizaion (RHCP and LHCP)...
any idea? In my opinion it's not achiveble.. I'm speaking about a "tested" gain.. not a "simulated" gain...
regards
Lupin
Try this link
Clk
so many choice you can and the best choice is to use the wideband antenna!
what if we want a reconfigurable antenna instead of dual band
that is antenna should be resonant at both freqs one at a time.
maybe by using a switch?
does anyone have any design guide for reconfigurable antenna
ie its dimensions, specs?
I like to have it in microstrip technology.
Thanks
i suggest to use Triangular antenna , it will be helpfull for you , it's a broadband antenna and have a good response at high frequencies .
