Is it possible to build Wilkinson power splitter using (3/4)*lambda lines?
Terminator3
Advanced Member level 3
Idea is to replace lambda/4 lines with 3*(lambda/4) line. Or 90deg with 270deg. In this case path between two ports will be 270x2=540deg (out of phase180 deg). And quaterwave transforming still works: d=lambda/4+ m*lambda/2... Is it correct?
