hi,
I have two sequences, s1 and s2. I have a property that checks these two sequences.
for example,
sequence s1
req ##3 gnt;
endseqence
sequence s2
ack;
endsequence
Now I make use of a property for an assertion to check these two sequences.
property p1;
@(posedge clk) disable iff(reset)
s1 |-> s2;
endproperty
assert property (p1) else $warning("Assertion failed");
Once the property has been asserted successfully, is there a way where I can trigger a signal (say X) HIGH? I want it to trigger HIGH only when the property has been successfully asserted during the rest of the time, I want it to be LOW.
Any suggestions would be of great help, thank you.
