I ran into what seems to be a malfunction of something, Kirchhoff's Law states "The algebraic sum of currents in a network of conductors meeting at a point is zero." But here it only seems to be true for the positive period of a sine, can anyone explain it? look here:
I personally don't like to relate the current direction here on the diode orientation.
According Kirchhoff one need the same direction to/from the node for all currents
--> Either all current vectors need to point to the node
...or away from the node.
ahh ok, in LTSpice the diode current vector is to the node, the other two are from the node. So LTSpice is not Kirchoff compatible (in lack of a better word)?
It's your job to arrange the current measurements in accordance with the circuit function. Each two terminal component has a fixed current measurement polarity assigned. If it doesn't point the right way, use a minus sign.
