sysysy
Member level 3
Hello everyone,
i use PIC16f877A USART to do my full duplex communication between 2 controllers....
Initially, i use jumpers, and the communication work well.
Then when i proceed this to RF modules (wireless communication)
then problem start occur. OK, since it is full duplex, so i use different frequencies of module which is one 315MHz pair and another one 433MHz pair. The problem the communication become invalid data received.
After do some troubleshooting, i found that if i only use 1 pair RF module and another way use jumper, the system work well again.... from there, i start suspect is interference problem again since, when two pair RF modules are not used together, system will work well.
But one thing i not sure is, why i already use two different frequencies modules, interference problem still occur? Or this may other problem? Can anyone give me advice and solution, thanks thanks.
