artiste
Newbie level 6
Hi everybody !
I've found that switch from Hittite having a IP3 of 74dBm. It's a T/R switch for Cellular/3G, TD-SCDMA, PMR,...
I do understand the necessity of having very high IP3.
But such a value of 74dBm is really needed ? For an amplifier of the same manufacturer, the highest IP3 I've found is 50dBm for a PA with a gain of 21.5dB.
From cascade IP3 calculation, a switch with an IP3 of 60dBm would give a cascaded IP3 of 48.7dBm while a switch with an IP3 of 74dBm give a cascaded IP3 of 49dBm.
I'm not an expert in system design but, it might not worth to use the switch with the IP3 of 74dBm....
Is there really applications that need such high IP3 ? If yes, please tell me !
Thanks in advance for your answers..
