Is GCC free along with all unix?
Shreehari
Member level 4
mangalore
GCC
Is gcc is free along with all linux ?.Tell me some free c ,C++ compilers and IDE for devolopment
Re: GCC
Yes it is free. For IDEs you can use eclipse.
Amr
    Shreehari
Re: GCC
Well, you can build ur own gcc for ur board. Read about Crosstool-NG. It will help you do that.
Amr Ali
    Shreehari
Re: GCC
all linux distros installs 'gcc' by default.
to check in your system ,
open a console and type
'gcc -v'
you will get some output
srizbf
24thjune2010
Re: GCC
OP needs to Modify the Heading with a detailed one. Or this thread will go to the trash can of the OP replies without it.
Re: GCC
now a days all of the linux versions are come with GCC in built...suppose if you are not find it then you can install GCC by
run the following commands as a root user....:?
fedora: yum install gcc
ubantu: apt-get install gcc
Re: GCC
GCC tools were not included during installation I have installed GCC compiler separately after UBUNTU installation.
@sip, Can you explain more about cross-platform IDE?
Re: GCC
@dharanidhar GCC and all development stuff is installed if the "development" type system is selected at the time of installation.
Well I use Fedora hence Cant comment about UBUNTU but There must be something similar.
Re: GCC
in ubuntu type the following command at the terminal " sudo apt-get install build-essential " this would install the essential build related stuff such as the gcc ( g++ ) compilers etc.
I didn't install using the .iso on CD/DVD...
I have installed using WUBI application which gave me no choices....
For Linux there are several free IDE's Anjuta, Eclipse, Qt Creator (can be used for c, c++ development without Qt) and of course
the combination shell+editor.
It's free to all the Unix we have seen ever before.but with a GPL licence.
