Rolloff curve is one factor. Another factor is overall resistance in the circuit.
It might also be expressed as Amperes going through the circuit.
High current, low Henry value.
Low current, high H.
Suppose your load is an 8 ohm speaker. Carrier frequency 44 kHz.
Suppose you want to let through as much signal as you can below 15 kHz. Reasonable inductive impedance target might be 8 percent of the load (call it 1 ohm.)
The formula for inductive impedance:
XL = 2 Pi f L
Solve for L in order to get a result for Henry value that gives you 1 ohm. Say it's approximate within an order of magnitude.
Simulate or test that inductive value in your circuit. Adjust value up and down to see how it affects response at your intended range of frequencies.
