is any difference in the adc section of attiny 461 and 461A
Dinuwilson
I am using attiny 461 for read voltage drop across a resistor via adc module, it"s work perfectly.... when i change to attiny 461A its not working....initially its shows some offset values.....why its happening... is any difference in adc section of both ic's...??
keith1200rs
Super Moderator
Staff member
Yorkshire, UK
So, it would appear you should be able to drop in the A version with no problems :???:
If you are writing to one of the two modified registers (rather than bit set/reset) it may cause an issue.
Keith
Dinuwilson
Thank's for your replay
