Is a new wave of analog techniques coming?
rfsystem
Advanced Member level 3
Germany
Analog DSP
Is analog showing how the physics works and outperform what is today understand as digital implementation technique and possible to early acknowleged as the future?
See also the Jan-2006 IEEE Solid-State Journal
Does a new wave of analog techniques come?
Re: Analog DSP
I've seen this statement quite a few times in recent 20 years. Every time this proved to be wrong. I dont held my breath this time too.
Re: Analog DSP
If a simple NAND2 in 65nm requires some 10fQ to execute a single operation, how many 10fQ is enough to process a 4bit addition in the analog domain? From the external side you have a digital interface (sooner or later an analog, haha). So how many NAND2 you need to process the 4bit addition in the digital domain? That could make a big difference in power consumption. As I think as scaling is dead, financial earlier than technical, new design techniques have to used to proceed with Moore Law. What do you think?
Re: Analog DSP
The main problem with analog DSP or CPU is complexity management.
Complexity is easily managed in software, less easily in digital hardware and extremely pourly managed in analog. So a properly designed computer platform is very complex in software (MS Windows, Unix, RTOS, etc.), less complex in digital HW (Pentium, MCU, DSP) and very simple in analog (PLL, I/O, A/D).
The current analog design techniques do no allow design anything that complex as simple programmable general 8bit MCU. Even a simple analog memory cell takes 1 week of analog designer and 1 week of layout in best case, while digital designer takes 1min to config memory compiler and thats it.
Once analog CAD gets to the level of digital one, we can think about pJ of switching energy.
Re: Analog DSP
I think Analog DSP is not as mature to compare design efficiency. The article in IEEE Solid-State Circuits page 42 2006 show that there is accuracy limitation and programming is done by signal flow diagramm in Simulink but the results are impressive and could find application where energy supply is critical.
