T
treez
Hello,
Which method is likely to be cheaper to produce?
1…Having a double sided PCB , with surface mount components on both sides, or
2….Having a 4 layered PCB, with surface mount components only on one side.
(This refers to a 10cm x 10cm offline SMPS PCB which also has some monitoring and control circuitry on the secondary side.)
