I Want to make a IR Counter which the Distance Between Transmitter and Receiver are 6 meters And I don't Need Any Modulation or Code Sending for It.
The Trasmitter LED is MLED81 Which I Didn't Find any DataSheet for it!
I Had Tried Many Circuits But None Of them worked.
Would You mind Helping me How to Build Very Simple IR Transmitter And Receiver
for 6 meter Range Only for Counting Purposes.
Why do u use infrared?? You can make with bright leds. All u have to do is replacing a lens infront of the led.. Receiver circuit is so simple...You can make it with 741 opamp IC and LDR...
