The foundry I/O library doesn't come with schematics, just layout,symbol and a netlist
I used the symbols to build the pad frame in schematic and used the layout cells to do it in Layout respectively.
When I try to run LVS, I get an error that schematic viewer can't netlist the I/O pad symbols(obviously lack of schematic). Where and how can I include the provided .cdl netlist to make Calibre pass the LVS?
Problem with stopping at smbol level will be that you will not verify the core layout vs schemastic just ios.
I believe calibre has chance of defining macro cells which will do the trick
