IO location for clock
maheyadav333
Member level 1
i have warning in plan ahead .
WARN: [HD-UCFReader 7] Clock terminal Clk is located on a non-clock IO location R8 this can produce sub-optimal results, line no : 6
where i should locate this clk
You should locate it on a package pin that is intended for a global clock. These pins are annotated with "GC", I beleive, in planAhead.
r.b.
if the board has already made ​​some sense to spend this clk transit through the crystal and connect straight to gclk pin. But not in altera
