jlee said:For your first question, do you mind to have a diode voltage drop on the output? If not, you can achieve the goal by a diode bridge, which works like a "negative" rectifier.
menewbie said:Hi, is there a circuit that can invert the sign of only positive signal? For example, if the input is 3V then the output is -3V and if input is -2V then the output is -2V.
Also, how to connect the output of a voltage divider to an integrator??
I am using 10p capacitors to divide the voltage but when I connect it to the integrator, which consists of an op-amp, a resistor(1k) and a capacitor(10u), the output of the voltage divider becomes 0V. I know I an impedance transformer can solve this problem. However, I am not sure what are the right values for the input resistance and the output resistance.
Chethan said:yes,
they are called polarity reversal circuits.
u can go thru the following link. it has got the block diagram of polarity reversal circuit.
h**p://sound.westhost.com/project90.htm
sixth said:For the first question, Maybe you need the combination of inverting amplifier, non-inverting amplifier, comparator and switches to realize this function.
For the second question, can give output your signal frequency?
sixth
Davood Amerion said:yes it's name is rectifier.
see this link:
h**p://www.play-hookey.com/analog/full-wave_rectifier.html
regards,
Davood.
20% !!!????menewbie said:... So using a rectifier would be harmful to the accuracy since the resistance varies 20% in the real world....
The full-wave rectifier depends on the fact that both the half-wave rectifier and the summing amplifier are precision circuits. It operates by producing an inverted half-wave-rectified signal and then adding that signal at double amplitude to the original signal in the summing amplifier. The result is a reversal of the selected polarity of the input signal.
BeeBop said:I don't think you even checked the link Davood gave you, did you?
It was a good reference, and since I didn't think you looked, I copied a line of text from the site:
It is not just a diode bridge. It will always put out a negative voltage, and is probably very accurate. I'm sure it'll be just as accurate as your next stage. Just go have a look, I think it'll serve you.
Best wishes,
Robert
BeeBop said:Yes, but not all resistors are 5%. Some are 10% (silver band?) some are 5% (gold) and you can get 1% which usually have 5 bands. So in a 5K resistor that amounts to plus or minus 500 ohms. What you could do is measure each of your precision resistors with a good ohm meter, and find two that are very nearly identical. This should give you what you need, no? Or you could do something like this with an instrument amp, which has very precise laser cut resistors, but usually costs around $20.
I couldn't stop thinking last night about what it is, exactly, that you are doing. That might help people help you.
Regards,
Robert
Kral said:menewbie,
The precision full wave rectifier shown at the website suggested by Dawood does exacly what you want. Preecision resistor networks are available with ratios matched to .01%.
Regards,
Kral
