inverter circuit diagram
CHLNO
Newbie level 1
NIGERIA
I want a 4v dc to 220v ac inverter circuit diagram.please send me the simplest circuit diagram to make it practically for home appliances.
The input should be 4v dc and the output should be 220v ac,50 Hz sine wave.
Send me the circuit diagram as soon as possible.
I'll fuel my Jumbo Jet and have my crew fly it straight out to you sir.
Do you realize what you are asking for? For every Amp you take out at 220V you have to put about 70 Amps in. Is your 4V battery capable of supplying such high current?
To make it practically, forget about using 4VDC input for large loads. And even if you were to make it, the circuit sure wouldn't be too simple.
I'm just curious which power source/battery you plan to use on input of inverter (4V) ?
Is it Lithium based battery and which capacity ?
You say "practically for home appliances", can you be more precize what power is needed ?
