Intruction time in Hitech C
luanktd
Newbie level 5
I write a function in hitech c, but i don't know exact intruction time, can you help me.
- what time to execute once intruction in hitech C?
Code C - [expand]
8
void delay( char x, char y)
do{
z=y;
do{;}while(--Z);
}while(--X);
// x=3,y=3. How many seconds this function delay?
If the MPLAB IDE is being utilized, you can use the MPLAB Simulator in conjunction with the Stopwatch Tool to measure the execution time of a routine of section of code:
Of course you can always calculate the duration of execution by counting the instruction cycles required for each of the resulting Assembly Language instructions.
BigDog
Thanks Big dog
i think it compiled to ASM, and follow me
LOOP DECFSZ COUNT_X,0
GOTO LOOP1
RETURN
LOOP1 DECFSZ COUNTY,0
GOTO LOOP1
GOTO LOOP
// AND INTRUCTION:
// DESFSZ: 1 CYCLE
// GOTO : 2 CYCLE
// RETURN: 2 CYCLE
// CALL FUNCTION IN HITECH C : 14 CYCLE
// SO RESULT:: DELAY = [3*(Y-1)+4]*[3*(X-1)+2]+14
// EXAMPLE:X=2,Y=8 :::::::::DELAY = [3*(8-1)+4]*[3*(2-1)+2]+14=139 CYCLE
Have you used the Stopwatch feature in MPLAB SIM to verify your calculation?
BigDog
