[PIC] Interruption on RB1 not working.
masashi11
Newbie level 5
Newbie level 5
I am having troubles with the interruptions on the pic18f4550, with the MPLAB 8.89 and c18 compiler.
The point is, the interruption doesnt get in if the pin change is status. I can see the status change, but it just doesnt change. But, if write the interruption as one it goes and enter the routine.
Here is my code, any idea?
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
////// Autonomated Velocity Transmssion for a Bicycle of 9 gears/////
#include <p18f4550.h>
//////////////////////////////////////////// Variables /////////////////////////////////////////////////
unsigned int sensors=0;              // Counter of the sensor in the star
unsigned int sensorw=0;              // Counter of the sensor in the wheel
unsigned int rpms=0;                 // Rpms of the star
unsigned int rpmw=0;                 // Rpms of the wheel
unsigned int velw;
//////////////////////////////////////////// Interruption functions //////////////////////////////////////////////////
void Llanta (void);                  //Wheel
void Estrella (void);                //Star
/////////////////////////////////////// High Priority Interruptions /////////////////////////////////////////////////
#pragma code high_vector=0x08
void high_interrupt (void)
     _asm nop _endasm
//////////////////////////////////////////// Low Priority Interruptions //////////////////////////////////////////////////
#pragma code low_vector=0x18
void low_interrupt (void)
    if(INTCON3bits.INT1IF==1){      //interruption for INT1 on rising edge
         _asm goto Llanta _endasm   //Wheel
    if(INTCONbits.RBIF==1) {        //Interruption for change on RB port change
        _asm goto Estrella _endasm  //Star
#pragma code
#pragma interruptlow Llanta
void Llanta (void)              //Counts when the hall sensor of the wheel is activated
    INTCON3bits.INT1IF=0;           //Turn off flag
    sensorw++;                    //add
#pragma interruptlow Estrella           //Counts when the hall sensor of the star is activated
    INTCONbits.RBIF=0;                  //Turn off flag
    if(PORTBbits.RB4 == 1){
        sensors++;                      //Add
////////////////////////////////////////////// Main program /////////////////////////////////////////////////////////////////////
void main (void)
    unsigned int temp16;
    OSCCON=0b01100000;          //Oscillator 4 MHz
    //Pins Configuration
    TRISBbits.RB1=1;            //input sensor wheel
    TRISBbits.RB4=1;            //input sensor star
    TRISB=0xFF;                 //All as inputs
    T1CON=0b01000001;           // Oscillator 4 MHz, timer 1
    ///////////////////////// Priorities ////////////////////////////////
    RCONbits.IPEN=1;            //Enable priority levels
    INTCON=0b11001000;          //Enable high, low interrupts and RB port change interrupt
    INTCON2=0b01110000;         //Pull up disabled, interrupt on rising edge, and low priority on rb change
    INTCON3=0b00011000;         //low priority interruption, and enables external interruptions.
    ADCON1=0x0F;                //digital input
    do{
        INTCON3bits.INT1IF=1;   // This was made to make a test. i put this as one, the interruption works and it goes where it should go.
    while(1);
View attachment Bicibici.txt
Maybe you have to configure ADCON1 regsister and make RBx pins digital input pins.
Hi there.
I already put in the configuration bits option the pbaden option off. And it makes the ports B digital inputs. Any other idea??
Is your Clock properly configured ? Please zip and post complete MPLAB project files so that it can be tested.
Sorry for the wrong post , maybe reading portb before activating interrupts could help?
Hi.
Thats an excellent question actually and to be honest i did not think about it.
Here is the code. Do you know what Clock should i check?
View attachment pim14.zip
No problem. Actually i am reading the value in PORTB all the time and i can see the change in the RB1 & RB2. But thats it, it just change the pins value from 0 to 1.
Hi. No problem :).
Yeah i read the values in PORTB all the time and i can see the change, but the interruption just does not pop up.
Please mention what clock you are using that is external crystal frequency.
Well thats a very good question I actually did not configure a Clock. What clock can i check?
Here is the project.
  • pim14.zip
WDT is enabled, I think. You have to disable it.
Try these config words.
Code C - [expand]
#pragma config PBADEN = OFF, PLLDIV = 1, CPUDIV = OSC1_PLL2, USBDIV = 2, FOSC = XT_XT, FCMEN = ON
#pragma config IESO = OFF, PWRT = ON, BOR = ON, BORV = 2, VREGEN = OFF, WDT = OFF, WDTPS = 2048
#pragma config CCP2MX = ON, LPT1OSC = OFF, MCLRE = OFF, STVREN = OFF, LVP = OFF, ICPRT = OFF
#pragma config XINST = ON, CP0 = OFF, CP1 = OFF, CP2 = OFF, CP3 = OFF, CPB = OFF, CPD = OFF
#pragma config WRT0 = OFF, WRT1 = OFF, WRT2 = OFF, WRT3 = OFF, WRTC = OFF, WRTB = OFF, WRTD = OFF
#pragma config EBTR0 = OFF, EBTR1 = OFF, EBTR2 = OFF, EBTR3 = OFF, EBTRB = OFF
I tried them and it just doesn't work. Is there a possibility where the Pins are burned off?
Even it is not working here. I wrote the code using mikroC and it works. Don't know what is the problem. One problem was RCON.IPEN setting. I removed it and everything worked fine. If Interrupt priority is enabled then you should set INTx interrrupts as high priority. I am attaching mikroC Code which works and also Proteus 8.2 SP2 format file.
I am also posting your code which I modified.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
//////////////////////////////////////////// Pragmacode /////////////////////////////////////////////////
#pragma config XINST = OFF, CP0 = OFF, CP1 = OFF, CP2 = OFF, CP3 = OFF, CPB = OFF, CPD = OFF
unsigned int sensors = 0;              // Counter of the sensor in the star
unsigned int sensorw = 0;              // Counter of the sensor in the wheel
unsigned int rpms = 0;                 // Rpms of the star
unsigned int rpmw = 0;                 // Rpms of the wheel
unsigned int velw;
void Llanta1 (void);                  //Wheel
void Llanta2 (void);                  //Wheel
void Llanta3 (void);                  //Wheel
    INTCONbits.RBIF = 0;
     _asm nop _endasm
    if(INTCONbits.INT0IF){      //interruption for INT1 on rising edge
        INTCONbits.INT0IF = 0;           //Turn off flag
        LATDbits.LATD0 = ~LATDbits.LATD0;
        _asm goto Llanta1 _endasm   //Wheel
    if(INTCON3bits.INT1IF){      //interruption for INT1 on rising edge
         _asm goto Llanta2 _endasm   //Wheel
    if(INTCON3bits.INT2IF){      //interruption for INT1 on rising edge
         _asm goto Llanta3 _endasm   //Wheel
    if(INTCONbits.RBIF) {        //Interruption for change on RB port change
#pragma code
#pragma interruptlow Llanta3
void Llanta1 (void)              //Counts when the hall sensor of the wheel is activated
void Llanta2 (void)              //Counts when the hall sensor of the wheel is activated
    INTCON3bits.INT1IF = 0;           //Turn off flag
    LATDbits.LATD1 = ~LATDbits.LATD1;
void Llanta3 (void)              //Counts when the hall sensor of the wheel is activated
    INTCON3bits.INT2IF = 0;           //Turn off flag
    LATDbits.LATD2 = ~LATDbits.LATD2;
    if(PORTBbits.RB4){
        LATDbits.LATD3 = ~LATDbits.LATD3;                      //Add
    INTCONbits.RBIF = 0;                  //Turn off flag
void main (void)
    ADCON1 = 0x0F;
    TRISB = 0xFF;                 //All as inputs
    TRISD = 0x00;
    T1CON = 0b01000001;           // Oscillator 4 MHz, timer 1
    INTCON  = 0b11111000;          //Enable high, low interrupt, INT0 and TMR0overflow and RB port change interrupt
    INTCON2 = 0b01110000;         //Pull up enabled, interrupt on rising edge, and low priority on rb change and tmr0 interrupt
    INTCON3 = 0b00011000;         //low priority interruption, and enables INT1 & INT2 interruptions.
                    //digital input
    INTCONbits.INT0IF =  0;     // Initialize flag of interrupt
    INTCON3bits.INT1IF = 0; // Initialize flag of interrupt
    INTCON3bits.INT2IF = 0; // Initialize flag of interrupt
    LATD = 0x00;
    do{
    while(1);
In MPLAB menu Configure > Configuration bits select config bits set in code.
  • Interrupts.rar
Also works with XC8 Compiler. I am sure the problem is with the ISR routines. The same code works fine in mikroC and XC8.
Fixed C18 code attached. Still there is some problem. INT2 doesn't toggle.
  • External_Interrupts.X.rar
  • pim14.rar
    V
Thanks. Going to try this in a moment in the pic with the XC8 compiler and i will tell you what happened.
I tried and something strange happened. It works sometimes.
For example the first time I tried it worked right. But after 6 hour i tried aggain and it didnt work.
Can this be a pic issue related?
The mikroC and XC8 codes work fine for me.
    V
My friend, now its working perfectly. I dont have an exactly idea of what was happenning but it was for sure
a hardware problem. Thanks for your help. Gona put your name in the project.
