Interrupt in pic 16F84A
saviourm
Junior Member level 3
Good Morning Guys
I am learning Interrupts using pic 16F84A.I tried this below program and worked well in my pic . I found this program on the web. I can't understand the interrupt speciaclly line between 13-18. **broken link removed**
org 0x00 ;This is where we come on power up and reset 1
;*******************SETUP CONSTANTS*******************
INTCON EQU 0x0B ;Interrupt Control Register 2
PORTB EQU 0x06 ;Port B register address 3
PORTA EQU 0x05 ;Port A register address 4
TRISA EQU 0x85 ;TrisA register address 5
TRISB EQU 0x86 ;TrisB register address 6
STATUS EQU 0X03 ;Status register address 7
COUNT EQU 0x0c ;This will be our counting variable 8
TEMP EQU 0x0d ;Temporary store for w register 9
goto main ;Jump over the interrupt address 10
;***************INTERRUPT ROUTINE***************
org 0x04 ;This is where PC points on an interrupt 11
movwf TEMP ;Store the value of w temporarily 12
incf COUNT,1 ;Increment COUNT by 1, and put the result 13
;back into COUNT
movlw 0x0A ;Move the value 10 into w 14
subwf COUNT,0 ;Subtract w from COUNT, and put the 15
;result in w
btfss STATUS,0 ;Check the Carry flag. It will be set if 16
;COUNT is equal to, or is greater than w,
;and will be set as a result of the subwf
;instruction
goto carry_on ;If COUNT is <10, then we can carry on 17
goto clear ;If COUNT is >9, then we need to clear it 18
carry_on
bcf INTCON,0x01 ;We need to clear this flag to enable 19
;more interrupts
movfw TEMP ;Restore w to the value before the interrupt20
retfie ;Come out of the interrupt routine 21
clear 22
clrf COUNT ;Set COUNT back to 0 23
bcf INTCON,1 ;We need to clear this flag to enable 24
;more interrupts
retfie ;Come out of the interrupt routine 25
;*******************Main Program*********************
main
;*******************Set Up The Interrupt Registers****
bsf INTCON,7 ;GIE – Global interrupt enable (1=enable) 26
bsf INTCON,4 ;INTE - RB0 Interrupt Enable (1=enable) 27
bcf INTCON,1 ;INTF - Clear FLag Bit Just In Case 28
;*******************Set Up The Ports******************
bsf STATUS,5 ;Switch to Bank 1 29
movlw 0x01 30
movwf TRISB ;Set RB0 as input 31
movlw 0x10 32
movwf TRISA ;Set R 0 to RA3 on PortA as output 33
bcf STATUS,5 ;Come back to Bank 0 34
;*******************Now Send The Value Of COUNT To Port A
loop 35
movf COUNT,0 ;Move the contents of Count into W 36
movwf PORTA ;Now move it to Port A 37
goto loop ;Keep on doing this 38
end ;End Of Program 39
As the opening lines of the tutorial say its designed to count the swtich actions from 0 up to 9.
When RB0 detects a change in condition, it interrupts the main program.
In the ISR, COUNT is incremented, then it is compared to see if it is equal to 10 or greater.
Bit C , Carry Flag, in the Status register is set according to the result of the compare; so by testing that bit with btfss , the next action can be determined.
That is either, it is not 10 so just carry on, or it is 10 so clear the counter back to 0.
One other thing to notice, you will see how the ISR starts and ends by storing and restoring W into Temp.
When you enter the ISR the values contained in important registers like W and STATUS can be lost.
It is normal to do whats called ' context saving' - this is detailed in the Pics datasheet - Interputs section - its wise to always use it.
		ORG     0x004             ; interrupt vector location
		movwf   w_temp            ; save off current W register contents
		movf	STATUS,w          ; move status register into W register
		movwf	status_temp       ; save off contents of STATUS register
; isr code can go here or be located as a call subroutine elsewhere
		movf    status_temp,w     ; retrieve copy of STATUS register
		movwf	STATUS            ; restore pre-isr STATUS register contents
		swapf   w_temp,f
		swapf   w_temp,w          ; restore pre-isr W register contents
		retfie                    ; return from interrupt
Dear all
Thankyou for your replay!!
Can soemone tell me what value has 'COUNT' in line 13 ?
The last question,I know that the value in W is 'A' Hex (line 14).Is it correct that the Instruction Subwf subtract W from 'Count' (Count minus W from pic datasheet)?I think that 'Count' is smaller than W and the result is negative (line 15) and can't understand this section.
Please can someone help me?
I will apperiacte!!!
Thank you in advance
Count is memory location defined by the user to store a value used during execution.
What value has the register 'Count' intialy, I don't understand is why the value of W is bigger than the value of "Count" ?,I think the subtraction result is negative(line 15).
Perhaps this might help.
When the program starts it is good practice to Clear your registers like Count, you cannot rely on the registers being Zero when powered up.
So ideally you would run the sub routine Clear just after the Main but before your Loop.
The logic of those lines is as follows.
Start - ( all values here hex)
Count = 00
Interrupt
Increment Count = 01
Load W with 0A
Subtract W From Count 01 minus 0A = F7
The STATUS register Carry bit becomes 0 as a result .
BTFSS STATUS,C then tests the conditon of bit C
If it dectects a 0 then the next instruction if executed so it will Carry on.
This loop will continue the same until count has gone up to 09 - then this happens
Count = 09
Interrupt
Increment Count = 0A
Load W with 0A
Subtract W From Count 0A minus 0A = 00
The STATUS register Carry bit 0 becomes 1 as a result .
If it dectects a 1 then the next instruction in jumped /ignored and the following instruction Clear is executed.
Hope thats cleared things up for you ..?
There is a feature of Mplab called MPLAB SIM where you can step though your code one instruction at a time and Watch the registers changing.
You can see where I have modified your code to the isr bit of code is in the main loop ( its easier to test that way).
Many thanks I know the program by heart .
Many thanks good night
