Internal error at Syn/plify
Laplace
Full Member level 1
Hey Guys,
After my verilog files are compiled at Sy/plify pro7.0, at the very beginning of synthesis step, I am getting "Internal error, please contact to Syn/plify support" message.
Has anyone got the same error before?
Thank you for your time.
I think you invoke synplify from ise5.1 with the os is winxp.
if so,do not set your winxp display mode as classic style,then it will be okay.
No...
I run syn/plify pro 7.02 on Linux red/hat 7.2.
Hi Laplace
Becuse you get the error at the beginning. I think maybe you haven't the right version of Synplify license
my_garden,
i have been using syn/plify for 3 years. I think I know how to install it and use it. Don't you think so?
I have a similar problem in my 7.2+w2k, but the problem gone with my 7.2+wxp. When I encountered this problem at w2k, I will close some of the applications and rerun the synthesis, then the process will be done without error. To some rare extreme cases, I need to reboot the PC and start the synthesis without running any other apps.
I think that may be due to runing out of some resources, as this workaround is working for my environment all the time, I don't look into deeper about the real cause and neither do I contact syn city as suggested in the error msg.
ntxp.
ntxp,
I think you are right. I am trying to synthsize a huge verilog code whic is about 7K lines. It consumes 42 % of 6M gate Virtex II.
I will try your suggestion and see what happens.
Thanks...
