In this circuit MOSFET is used as a switching device, if I want to generate waveform like fullwave rectifier output, then which type of pwm signal provides to MOSFET drive circuit.
usually, a full wave rectifier would supply the input bus voltage needed by the interleaved active clamp flyback.
You cant make a full wave rectifier with an interleaved active clamp flyback
as per the figure we provides a dc voltage as a input to the interleaved active clamp flyback converter block, provide a PWM signal to the MOSFET which is in interleaved block for switching purpose. PWM signal is generated by the microcontroller which has a fix frequency 57 KHz and 50 % duty cycle then we got a output like triangular waveform. actually we will need a output like a given figure so which type of PWM output will be provided to the switching MOSFET, so we got proper output of the interleaved active clamp flyback converter.
