interfce with DS1307 RTC
sudheepsrc
Junior Member level 3
kerala
plz help me do project......
in my project using a RTC Ds1307 .But have doubt, plz help meeeee
1) Firstly we entering current calender?
2) IF yes hows that do?
thanks in advance .......................
The DS1307 uses an I2C interface. Through this interface you can read or write the internall registers that controll all its functions, like calendar and alarm. So, firstly, connect the device to an I2C interface. Then, read the datasheet and write to the internall registers (at address 00h to 06h) that controll date and time (and others if you wish).
Regards
Hi, I´m wondering about what are you trying to build (I guess you want to build a Real Time Clock to use with some other circuits) but, as an advice, I suggest you to build a board like the one I built some months ago that lets you interface the DS1307 in a easy way. After that we would like to know if you want to make it work with a PIC or other Microcontroller... let us know that to help you... I made a try with a PIC16F876A and Mikrobasic and I could lend you this work if you need it... Anyway you need to read the datasheet of the chip (as pauloynski said to you) and to pay attention in all steps you are interested in. Here you have the pictures of the interface board I made. Greets.
DS1307 RTC is interface using I2C interface.
you have set time and then start the clock..
later u can read the time
here is program which sets time and reads time using PC interface MAX232..
on hyperterminal
here u can find datasheet
see my post
https://www.edaboard.com/threads/188521/
this will help you in code
