Rahul Kumar Vashistha
guys please help me out!
i am trying to interface two ultrasonic sensors(HC-SR04) with pic16f877a and accordingly have written the code as shown below:-
tried simulating in proteus but i am getting undesired o/p.
please help..
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 #define _XTAL_FREQ 8000000 #define RS RD2 #define EN RD3 #define D4 RD4 #define D5 RD5 #define D6 RD6 #define D7 RD7 #include <xc.h> #include <pic16f877a.h> void Lcd_Port(char a); void Lcd_Cmd(char a); void Lcd_Set_Cursor(char a, char b); Lcd_Clear(); void Lcd_Init(); void Lcd_Write_String(char *a); void Lcd_Shift_Right(); void Lcd_Shift_Left(); void Lcd_Write_Char(char a); void sendo(); // BEGIN CONFIG #pragma config FOSC = HS // Oscillator Selection bits (HS oscillator) #pragma config WDTE = OFF // Watchdog Timer Enable bit (WDT enabled) #pragma config PWRTE = OFF // Power-up Timer Enable bit (PWRT disabled) #pragma config BOREN = ON // Brown-out Reset Enable bit (BOR enabled) #pragma config LVP = OFF // Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit (RB3 is digital I/O, HV on MCLR must be used for programming) #pragma config CPD = OFF // Data EEPROM Memory Code Protection bit (Data EEPROM code protection off) #pragma config WRT = OFF // Flash Program Memory Write Enable bits (Write protection off; all program memory may be written to by EECON control) #pragma config CP = OFF // Flash Program Memory Code Protection bit (Code protection off) //END CONFIG int a; void interrupt echo() { if(RBIF == 1) //Makes sure that it is PORTB On-Change Interrupt { RBIE = 0; //Disable On-Change Interrupt if(RB4==1 && RB5==1) { TMR1ON = 1; if((RB4==0)|| (RB5==0)) TMR1ON=0; a = (TMR1L | (TMR1H<<8))/58.82; a=a+1; if(a>=2 && a<=400) { Lcd_Clear(); Lcd_Set_Cursor(1,1); Lcd_Write_String("Speedbreaker"); Lcd_Set_Cursor(2,1); Lcd_Write_String("Distance = "); Lcd_Set_Cursor(2,14); Lcd_Write_Char(a%10 + 48); a = a/10; Lcd_Set_Cursor(2,13); Lcd_Write_Char(a%10 + 48); a = a/10; Lcd_Set_Cursor(2,12); Lcd_Write_Char(a%10 + 48); Lcd_Set_Cursor(2,15); Lcd_Write_String("cm"); } else { Lcd_Clear(); Lcd_Set_Cursor(1,1); Lcd_Write_String(" of Range"); } __delay_ms(400); //sendo(); } if(RB4 == 1 || RB5==1) { TMR1ON = 1; } if(RB4==0 || RB5==0) { TMR1ON = 0; //Stop Timer a = (TMR1L | (TMR1H<<8))/58.82; //Calculate Distance } } RBIF = 0; //Clear PORTB On-Change Interrupt flag RBIE = 1; //Enable PORTB On-Change Interrupt } void main() { TRISB = 0b00110000; //RB4 as Input PIN (ECHO) TRISD = 0x00; // LCD Pins as Output GIE = 1; //Global Interrupt Enable RBIF = 0; //Clear PORTB On-Change Interrupt Flag RBIE = 1; //Enable PORTB On-Change Interrupt Lcd_Init(); Lcd_Set_Cursor(1,1); Lcd_Write_String("yo"); Lcd_Set_Cursor(2,1); Lcd_Write_String("mAn"); __delay_ms(3000); Lcd_Clear(); T1CON = 0x10; //Initialize Timer Module while(1) { TMR1H = 0; //Sets the Initial Value of Timer TMR1L = 0; //Sets the Initial Value of Timer RB0 = 1; //TRIGGER HIGH __delay_us(10); //10uS Delay RB0 = 0; //TRIGGER LOW __delay_ms(100); //Waiting for ECHO a = a + 1; //Error Correction Constant if(a>=2 && a<=400) //Check whether the result is valid or not { Lcd_Clear(); Lcd_Set_Cursor(1,1); Lcd_Write_String("Distance = "); Lcd_Set_Cursor(1,14); Lcd_Write_Char(a%10 + 48); a = a/10; Lcd_Set_Cursor(1,13); Lcd_Write_Char(a%10 + 48); a = a/10; Lcd_Set_Cursor(1,12); Lcd_Write_Char(a%10 + 48); Lcd_Set_Cursor(1,15); Lcd_Write_String("cm"); } else { Lcd_Clear(); Lcd_Set_Cursor(1,1); Lcd_Write_String("Out of Range"); } __delay_ms(400); } } //LCD Functions void Lcd_Port(char a) { if(a & 1) D4 = 1; else D4 = 0; if(a & 2) D5 = 1; else D5 = 0; if(a & 4) D6 = 1; else D6 = 0; if(a & 8) D7 = 1; else D7 = 0; } void Lcd_Cmd(char a) { RS = 0; // => RS = 0 Lcd_Port(a); EN = 1; // => E = 1 __delay_ms(4); EN = 0; // => E = 0 } Lcd_Clear() { Lcd_Cmd(0); Lcd_Cmd(1); } void Lcd_Set_Cursor(char a, char b) { char temp,z,y; if(a == 1) { temp = 0x80 + b - 1; z = temp>>4; //10000000,z=00001000 y = temp & 0x0F; //10000000 & 00001111 = 0 Lcd_Cmd(z);// Lcd_Cmd(y); } else if(a == 2) { temp = 0xC0 + b - 1; //11000000 z = temp>>4;//00001100 y = temp & 0x0F;//0000 Lcd_Cmd(z);//0X0C Lcd_Cmd(y);//0x00 } } void Lcd_Init() { Lcd_Port(0x00); __delay_ms(20); Lcd_Cmd(0x03); __delay_ms(5); Lcd_Cmd(0x03); __delay_ms(11); Lcd_Cmd(0x03); Lcd_Cmd(0x02); Lcd_Cmd(0x02); Lcd_Cmd(0x08); Lcd_Cmd(0x00); Lcd_Cmd(0x0C); Lcd_Cmd(0x00); Lcd_Cmd(0x06); } void Lcd_Write_Char(char a) { char temp,y; temp = a&0x0F; y = a&0xF0; RS = 1; // => RS = 1 Lcd_Port(y>>4); EN = 1; __delay_us(40); EN = 0; Lcd_Port(temp); EN = 1; __delay_us(40); EN = 0; } void Lcd_Write_String(char *a) { int i; for(i=0;a[i]!='\0';i++) Lcd_Write_Char(a[i]); } void Lcd_Shift_Right() { Lcd_Cmd(0x01); Lcd_Cmd(0x0C); } void Lcd_Shift_Left() { Lcd_Cmd(0x01); Lcd_Cmd(0x08); } /*void sendo() { if(RB4!=1) { TMR1ON=0; a = (TMR1L | (TMR1H<<8))/58.82; } if(a>=2 && a<=400) { Lcd_Clear(); Lcd_Set_Cursor(1,1); Lcd_Write_String("Speedbreaker"); Lcd_Set_Cursor(2,1); Lcd_Write_String("Distance = "); Lcd_Set_Cursor(2,14); Lcd_Write_Char(a%10 + 48); a = a/10; Lcd_Set_Cursor(2,13); Lcd_Write_Char(a%10 + 48); a = a/10; Lcd_Set_Cursor(2,12); Lcd_Write_Char(a%10 + 48); Lcd_Set_Cursor(2,15); Lcd_Write_String("cm"); } else { Lcd_Clear(); Lcd_Set_Cursor(1,1); Lcd_Write_String(" of Range"); } __delay_ms(400); }
please help..
