sathish316
Junior Member level 2
at command c35
I`m trying to interface a Siemens C35 Mobile Phone to my PC. I`m using a Software called Siemens Mobile Control to operate the Mobile phone from PC. The software keeps saying "Unconnected to Mobile". I tried few other siemens software. Nothing seems to work.
This software has provisions for setting the baud rates, DTR, RTS etc. Can anyone pls help me with the exact baud rate settings for the mobile.
Is there a way to check whether the GSM modem and AT Command set are working perfectly frm Hyper terminal. If u do, pls sens me the sequence of instructions to be used to chk if the interface works.
I used a Data cable which has a marking C25 on it. I dont think that is the problem bcos it interfaces perfectly with the mobile. Is there any difference between the data cables for siemens C25 and C35?
When i try to run a SelfTest on the mobile it shows a Mobile--PC connection when the software is running and not able to connect. But it shows only a mobile(no PC) when the software is closed.
Can anyone pls help me locate and correct the prob. even if u can think of some other sources of the prob pls guide me
tnx
sathish
tnx
sathish
