Ranjitharanju
Hi All,
I am trying to interface RTC(DS1307 WITH I2C ) with pic24fj128ga010, somewhere i m doing mistake but i m not getting where please can any one find wt i m doing wrong and help me please..
here is my code
Thanks.
here is my code
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 #include <libpic30.h> #include<p24fj128ga010.h> #define FCY 16000000 _CONFIG1( JTAGEN_OFF & GCP_OFF & GWRP_OFF & COE_OFF & FWDTEN_OFF & ICS_PGx2) _CONFIG2( FCKSM_CSDCMD & OSCIOFNC_OFF & POSCMOD_HS & FNOSC_PRIPLL) #define SECOND 0x00 #define MINUTE 0x01 #define HOUR 0X02 #define DAY 0x03 #define DATE 0x04 #define MONTH 0X05 #define YEAR 0X06 unsigned char TIME[6]=" : : "; unsigned char sec,min,hour,day,date,month,year; unsigned char date_day[9] = "00/00/0000"; //****************I2C DRIVERS*************************** void __attribute__((interrupt,no_auto_psv)) _MI2C1Interrupt(void) { //do nothing IFS1bits.MI2C1IF = 0; } void I2c_init(void) { //TRISGbits.TRISG2 = 1; //TRISGbits.TRISG3 = 1; //I2C1STAT= 0x0030; I2C1STAT= 0x0000; //I2C1CON = 0x1240; I2C1CON = 0x8000; //I2C1ADD = 0x0D; I2C1MSK = 0x0000; I2C1BRG = 79; //BUAD RATE 100KHz //IEC1bits.MI2C1IE = 1; //I2C1CONbits.I2CEN = 1; } void start(void) //start of i2c { I2C1CONbits.SEN = 1; while(I2C1CONbits.SEN); } void stop(void) //stop i2c { I2C1CONbits.PEN = 1; while(I2C1CONbits.PEN); } void repeate_start(void) //restart i2c { I2C1CONbits.RSEN = 1; while(I2C1CONbits.RSEN); } void data_byte_write(unsigned char write_dat) //writing from master to slave { I2C1TRN =write_dat; // while(I2C1STATbits.TBF); // Write Information bit waiting for tbf = 1; } unsigned char data_byte_read(unsigned char ack) { unsigned char recval; I2C1CONbits.RSEN = 1; while(I2C1CONbits.RSEN); //I2C1RCV = I2C1TRN; recval = I2C1RCV; __delay32(40); while(I2C1STATbits.RBF); while(!IFS1bits.MI2C1IF); if(ack == 0) { I2C1CONbits.ACKDT = 0; } else if(ack == 1) { I2C1CONbits.ACKDT = 1; } I2C1CONbits.ACKEN = 1; while(I2C1CONbits.ACKEN); return(recval); } unsigned char getdata(unsigned char address) //reading the data from slave { unsigned char val; I2C1CONbits.I2CEN = 1; start(); data_byte_write(0xD0); //slave address while(!IFS1bits.MI2C1IF); while(I2C1STATbits.ACKSTAT); data_byte_write(address); while(!IFS1bits.MI2C1IF); while(I2C1STATbits.ACKSTAT); repeate_start(); data_byte_write(0xD0+1); while(!IFS1bits.MI2C1IF); while(I2C1STATbits.ACKSTAT); val = data_byte_read(1); stop(); I2C1CONbits.I2CEN = 0; return (val); } //**********************END OF I2C DRIVERS************** int main (void) { while(!OSCCONbits.LOCK ); // CLOCK FREQUENCY I2c_init(); while(1) { // __delay_ms(100); sec = getdata(SECOND); min = getdata( MINUTE); hour = getdata(HOUR); day = getdata(DAY); date = getdata( DATE); month = getdata(MONTH); year = getdata(YEAR); } return 0; }
Thanks.
