parimal.panchani
Newbie level 1
- Joined
- Jun 25, 2013
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 10
I am using flash magic for programming P89V51RD2.
But when i connect USB to serial cable with circuit board then pins of max232 (pin13,pin14,pin1,pin2) are getting shorted and voltage level on PORT1 of controller goes HIGH (4.8 V).
So when i am trying to load the code it gives error "failed to read device signature(unable to transmit/receive) Accessing the device using wrong protocol".
Please tell me solution whether problem is with max232 or with controller.?
I have also changed max232. but same problem exists.
I am using simple circuit for programming controller in ISP mode. I have attached circuit diagram.
