interfacing my melody cicuit with microcontroller ...
ammuvinu
Newbie level 5
hi all
i have uploaded an image in which i have constructed a melody cicuit which is working well.
iam able to create all the 7 basic tones and also hear it through the speaker .
now my major doubt is , is it POSSIBLE TO INTERFACE THIS CIRCUIT WITH A MICROCONTROLLER AND SAVE MY INPUT AND PLAY WHEN EVER I NEED IT .
or else which circuit will help me to input my own melody through a keyboard and save it and play it
later
if my above circuit will not work or if its useless to store melody please help me with a circuit which will help me to input my own melody(to input music codes in RTTL format) and save it in microcontroller and play it
:D[/u]
ammuvinu said:
...now my major doubt is , is it POSSIBLE TO INTERFACE THIS CIRCUIT WITH A MICROCONTROLLER AND SAVE MY INPUT AND PLAY WHEN EVER I NEED IT..
Say it so, such interfacing is possible, but its no helpend for you...
If you will change the switches with the capacitors: you can these control over a port/output trasistors of your uC, details are depend of concret uC..
ammuvinu said:
...if its useless to store melody please help me with a circuit which will help me to input my own melody(to input music codes in RTTL format) and save it in microcontroller and play it [/b][/u]
:D[/u]
Remember pls, it hasnt such memory, you can not storage the settings from it, you can only control it as a output device!
I dont understand why dont you pls search for some dedicated "melody generators/ICs" on the web!?
you will/can find lot of them & their are (relative) perfect sound generators/effect sources.
Lot of games has that inside or such "music cards" too, you can select special versions too, their are designed to work with a UC, as your application it wishes:)
Pls read such home made electronic sides_it exists very much & with circuits & good ideas too , not to last are magazines to find; such are on-line too!...
Some: Elector/Elrad/ELV/ www.circuitcellar.com(search for archive..), or you can simple in google/yahoo search for "melody generator circuit w. microcontroller interfacing etc..)
K.
    ammuvinu
ammuvinu said:
hi all
Yes indeed. Google "Roman Black 1 bit sound" Exactly what you need. Also make sure to look about 1/3 down the page and check out the TalkBotBrain project.
