Interfacing mcp3422 with microcontroller
Arya Kumar
Member level 4
Hello all,
i am doing this project to learn about I2c protocol. i have earlier interfaced eeprom with controller and that was easy .
I have problem inerfacing it to mcp3422 Analogue module.
I am using MIKROC IDE , controller is PIC16f877a and coding in c.
Objective - to read anlogue value with default configurations
void main(){
  PORTB = 0;
  TRISB = 0;                 // Configure PORTB as output
    while(1)
  I2C1_Init(100000);         // initialize I2C communication    \
  I2C1_Start();              // issue I2C start signal
  I2C1_Wr(0xd0);             // send byte via I2C  (device address + W) // device identifer is 1101 and MCP3422 has no external Address line + write (0)
                                         // 1101 000 0 = 0xD0
  //I2C1_Wr(0x55);                // send byte (data address)     // no idea what to put here.. i am usig same format as i did for eeprom
                                         // i see no regiser address to read or write
  I2C1_Repeated_Start();     // issue I2C signal repeated start
  I2C1_Wr(0xd1);             // send byte (device address + R) write address +1
  PORTB = I2C1_Rd(1u);       // Read the data // no idea how to read more than 8 bits.  ???
  PORTB = I2C1_Rd(1u);      // have to read 3 bytes of data from module
  I2C1_Stop();               // issue I2C stop signal
  delay_ms(1);
I have attached code and proteus simulations :-|
Please help as u all always do. Till then i will try to explore problem by myself,
Thanks and Regards,
Arya Kumar:thumbsup:
  • i2c_perpherals.zip
i am unable to read ADC value from I2C1_Rd(1u);
it always returns 0x00;
hello,
You need to do some initialisation for your ADC MCP3222 .. befor getting a result
i used this for a MCP3224 and PIC18F258 with MikroC ..maybe it can help you
#define MCP3424_Adr 0xD0
unsigned long M=0 ;          // mesure ADC 18 bits
unsigned short MCPCfg;
unsigned short MCP_CH;
unsigned short MCP_Resol;
unsigned short MCP_Gain;
//--------- ADC 18 bits --------------------
unsigned long read_adc_value()
{  unsigned short erreur;
  unsigned short EtatCf;
  unsigned long value=0L;
  unsigned char *pV;
  pV=&value;
     erreur=0;
  // RDY=1 init One Shoot conversion
  // MCP_CH * 32  (bit 6-5)  numero de chanel  0 à 3
  // MCP_Resol    (Bits 3-2) 0x11  0C-> 18bits 3.75SPS
  // MCP_Gain=0   bits 1-0  0x00
  MCPCfg= 128 + MCP_CH + MCP_Resol + MCP_Gain;
  Soft_I2C_Start();
  erreur=Soft_I2C_Write(MCP3424_Adr);    // 0xD0
  erreur=Soft_I2C_Write(MCPCfg);
     //Soft_I2C_Write(0x88);   // 0x8C=140 pour 18 bits    0x88= 136 pour 16 bits
  Soft_I2C_Stop();
  Soft_I2C_Start();
  erreur=Soft_I2C_Write(0xD1);     // LECTURE adresse fixe + 000 + R=1
  *(pV+3)=0;
  *(pV+2)= Soft_I2C_Read(1); // lit et renvoi  ACK
  *(pV+1)= Soft_I2C_Read(1);  // lit et renvoi ACK
  *(pV+0)= Soft_I2C_Read(1); // lit et renvoi  ACK
  EtatCf=  Soft_I2C_Read(0); // lit et renvoi NACK
  Soft_I2C_Stop();
  return value;
MCP register initilized in the main program
the result is a long inter 32 bits ...
ok i have added default configuration to my code.
Still no fruits. If u can just send ur full project with simulation. That will make my day.
void main(){
  PORTB = 0;
    while(1)
[B][COLOR="#FF0000"]  I2C1_Wr(0x90);                // writing default configuration   1001 0000[/COLOR][/B]
  PORTB = I2C1_Rd(1u);       // Read the data      /// by default we are in 12 bit mode
  delay_ms(100);
  delay_ms(100);
  delay_ms(1);
hello,
What voltage level do you apply on CH1 Analog MCP entry ?
+VCC ??
put a value corresponding to half of the scale measurment to do tests ..
I don't have PROTEUS neither simulator, i only work in real world .. even with breadboard
i think it is more easy to debug .
some explanation (sorry ,in French) on MCP3224 and other ADC via **broken link removed** ..
I know it must not be 5 volt. But as of now i just want any value other than zero on the I2c bus. I have changed it to other levels still it return zero.
I dont know but above link is banned in India
in your I2C debug you don´t show 3rd and 4th byte.
4th byte is the config byte and may give additional information.
Klaus
