Interfacing LCM128643 with PIC16F887
JJC
Newbie level 1
Newbie level 1
I am working on code to display analog clock on LCM128643 GLCD, also, i am using ccs pcm compiler. the problem is that the circle dis played is elliptical rather than circular. i could not fix it as i am new in microcontrollers programming. someone please help solve this problem elliptical display of circles
thanks
The circle is displayed as an ellipse due to the aspect ratio of the display, sort of like an HD vs Standard Format TV. I'm sure you've seen a standard format movie stretched to fit a HD format screen. Everbody is short and fat. What are you using to draw the circle, a library function or a routine you wrote?
