interfacing keypad with 89c52
misha82
Member level 2
Member level 2
hi
can anybody give me an idea how to interface a keypad with 4 keys with a microcontroller 89c51?
thanx
Sooner or later you'll need more than 4.
Watch these slides:
i use 89s52 but the principle is same :) maybe is not the best variant but work !
while(1)
Sw_State = Switch_Get_Input(10);
Display_Switch_Update(Sw_State);
char Switch_Get_Input(const unsigned char debounce_period)
char Return_value = 0x00;
if(Switch_Pin_1 == 0)
delay_ms(debounce_period);
while(Switch_Pin_1 == 0);
Return_value = 0x01;
if(Switch_Pin_2 == 0)
while(Switch_Pin_2 == 0);
Return_value = 0x02;
if(Switch_Pin_3 == 0)
while(Switch_Pin_3 == 0);
Return_value = 0x03;
if(Switch_Pin_4 == 0)
while(Switch_Pin_4 == 0);
Return_value = 0x04;
return Return_value;
void Display_Switch_Update(const char SWITCH_STATUS)
switch (SWITCH_STATUS){
case 0x01 :
Some command;
break;
case 0x02 :
Some command;
break;
case 0x03 :
Some command;
break;
case 0x04 :
Some command;
break;
default:
Some command;
break;
..::SyRaX:..
HI All
Plz help me i m new in micro controller.i m using 89s51 mc and want to make a keypad lock using it. so plz help me out.
casamiro
simple way:
make variable enabled
and then :
if(enabled){
get_key();
if you wanna lock keys just make enabled = 0
