Twisted_transistor
Member level 1
HI.. This is the code I've written to send an sms via the GSM modem interfaced with LPC2148.. But however the number to which the message has to be sent does not receive any message..
Can someone pls help me understand why this is happening?
This is the code:
I'm using SIM300 by the way.
Thanks in advance
This is the code:
#include "LPC214x.h"
void init(void);
extern unsigned char cmgf[]="AT+CMGF=1"; //Text format in GSM modem
extern unsigned char cmgs[]="AT+CMGS=\"##########\""; //Mobile number to which the msg is sent
extern unsigned char msg[]="Hello"; //secret code
void senduart1(unsigned char a) //sends a byte through U1
U1THR=a;
while(U1LSR!=0x60);
void sendstring(unsigned char *p) //Sends a string of data through UART1
while(1)
if(*p=='\0') break;
senduart1(*p++);
void delaygsm() //delay function
int i,j;
for(i=0;i<60000;i++)
for(j=0;j<51;j++);
int main()
PINSEL0=0x00050005; //initialized U0 and U1 as UART and not GPIO
PINSEL1 = 0x00000000;
PINSEL2 = 0x00000000;
init();
sendstring(cmgf);
senduart1(0x0d); // equivalent of
senduart1(0x0a); // enter key
delaygsm();
sendstring(cmgs);
senduart1(0x0d);
senduart1(0x0a);
delaygsm();
sendstring(msg);
senduart1(0x1a);
void init()
U1LCR=0x83; //8-N-1, enable divisors
U1DLL=0x62; //9600 baud (9615)
U1DLM=0x00;
U1LCR=0x03; //8-N-1, disable divisors
Thanks in advance
