[ARM] Interfacing GPS module for LPC2148 Micro Controller
K Srinivas Pavan Kumar
Member level 3
Hi.
can anybody help me by providing me the interfacing of GPS module with LPC2148
The interface between the GPS module(specific manufacturer) & LPC2148 is the
serial communication like UART.
The module continuously sends that serial data containing the location parameters like
longitude & latitude etc...
In the serial data string first six bytes matches with the string like ($GPGGA)
then it is considered as valid data & perform string manipulation to extract data from
specific locations in string.
If the data string first six bytes doesn't match ($GPGGA), then should discard that
& considered as invalid data.
In this critical part is to establish communication between the micro controller &
module.
I want to see the latitude and longitude values in my LCD
In which I have seen the values for atmega using the AVR board
Step 1: you should up your micro controller board with specific frequency.
Step 2: Implement & check GPIO's.
Step 3: Implement UART driver & perform the echo test with help of terminal.
Step 4: Choose 16 X 2 LCD & implement basic LCD driver.
Step 5: Send data to the LCD from PC with help of UART driver & check it.
Step 6: Implement the GPS interface driver with micro controller with help of UART driver.
Step 7:write your application as per your need i.e longitude, latitude etc..data from the data string
from the GPS module & perform string manipulations & can display that values on 16 X 2 LCD help
of implemented LCD driver.
Step 8: I think it's fulfill your need, in development phase first need to develop the basic interface &
check them, and should concentrate on application development.
